könntest Du bitte den relevanten Teil Deiner userconfig.txt posten, also die oberen Zeilen ohne die Filter?
ohne Conlvolver also über squeezlite läuft die Wiedergabe ohne Probleme
USEBETA="OFF"
PLATFORM="AroioEX"
USERPASSWD="abacus"
HOSTNAME="AroioOS"
LAN_DHCP="ON"
LAN_IPADDR=""
LAN_NETMASK=""
LAN_DNSSERV=""
LAN_GATEWAY=""
WLAN_DHCP="ON"
WLAN_IPADDR=""
WLAN_NETMASK=""
WLAN_DNSSERV=""
WLAN_GATEWAY=""
WLANSSID="XXXXX"
WLANPWD="XXXXXXXXXX"
SERVERNAME="file-server"
SERVERPORT=""
SQUEEZEUSER=""
SQUEEZEPWD=""
PLAYERNAME="AroioOS"
BTKEY="2107"
ADVANCED="ON"
CHANNELS="2"
RATE="96000"
SPRATE="44100"
MSCODING="OFF"
RESAMPLING="speexrate_medium"
VOLUME_START="255"
JACKBUFFER="512"
JACKPERIOD="3"
SQUEEZE_ALSABUFFER="4096"
SQUEEZE_ALSAPERIOD="3"
SQUEEZE_INTBUFFER="2048"
SQUEEZE_OUTBUFFER="4096"
BF_PARTITIONS="4"
SOUNDCARD="IQAudIO DAC"
DEBUG=""
AUDIO_OUTPUT="vol-plug"
RAW_PLAYER="squeezelite"
RAW_PLAYERMS="squeezelite"
DMIX_SQUEEZELITE="ON"
DMIX_GMEDIARENDER="ON"
DMIX_SHAIRPORTSYNC="ON"
DMIX_BLUEALSAAPLAY="ON"
DMIXMS_SQUEEZELITE="ON"
DMIXMS_GMEDIARENDER="ON"
DMIXMS_SHAIRPORTSYNC="ON"
DMIXMS_BLUEALSAAPLAY="ON"
JACK_SQUEEZELITE="ON"
JACK_GMEDIARENDER="OFF"
JACK_SHAIRPORTSYNC="OFF"
JACK_BLUEALSAAPLAY="OFF"
JACK_NETJACK="OFF"
JACK_INPUT="OFF"
JACKMS_SQUEEZELITE="ON"
JACKMS_GMEDIARENDER="OFF"
JACKMS_SHAIRPORTSYNC="OFF"
JACKMS_BLUEALSAAPLAY="OFF"
JACKMS_NETJACK="OFF"
JACKMS_INPUT="OFF"
JACKBF_SQUEEZELITE="ON"
JACKBF_GMEDIARENDER="OFF"
JACKBF_SHAIRPORTSYNC="OFF"
JACKBF_BLUEALSAAPLAY="OFF"
JACKBF_NETJACK="OFF"
JACKBF_INPUT="OFF"
JACKBFMS_SQUEEZELITE="ON"
JACKBFMS_GMEDIARENDER="OFF"
JACKBFMS_SHAIRPORTSYNC="OFF"
JACKBFMS_BLUEALSAAPLAY="OFF"
JACKBFMS_NETJACK="OFF"
JACKBFMS_INPUT="OFF"
LOAD_PREFILTER="ON"
USEBETA="OFF"
PLATFORM="AroioEX"
USERPASSWD="abacus"
HOSTNAME="AroioOS"
LAN_DHCP="ON"
LAN_IPADDR=""
LAN_NETMASK=""
LAN_DNSSERV=""
LAN_GATEWAY=""
WLAN_DHCP="ON"
WLAN_IPADDR=""
WLAN_NETMASK=""
WLAN_DNSSERV=""
WLAN_GATEWAY=""
WLANSSID="XXXXX"
SERVERPORT=""
SQUEEZEUSER=""
SQUEEZEPWD=""
BTKEY="2107"
ADVANCED="ON"
CHANNELS="2"
RATE="96000"
SPRATE="44100"
MSCODING="OFF"
VOLUME_START="255"
JACKBUFFER="512"
JACKPERIOD="3"
BF_PARTITIONS="4"
DEBUG=""
JACK_NETJACK="OFF"
JACK_INPUT="OFF"
JACKMS_INPUT="OFF"
JACKBF_INPUT="OFF"
LOAD_PREFILTER="ON"
danke für das Feedback. Seltsam, bei mir liefen die Parameter sauber durch. Der Unterschied ist, dass ich den AroioDAC drin habe und den Raspberry 3B (ohne +).
Ich werde mal versuchen, das mit deiner Konstellation nachzustellen. Außerdem könntest du einfach mal versuchen, vorsichtig an den verschiedenen Stellschrauben zu drehen und zu gucken, ob es mit anderen Parametern stabiler läuft.
Denis
Habe soeben eine neue Bestellung getätigt. Wird wohl für das Gästezimmer herhalten
Rasp Pi3 B+
Hifiberry DAC (Standard)
Gehäuse
Allnet BT-Stick.
Per BT könnte ich halt gut vom Laptop (mein Arbeitstier) aus Streamen.
Ich werde es mal durchprobieren.
Reicht eine 2GB SD-Karte für AroioOS?
Rasp Pi3 B+
Gehäuse
Allnet BT-Stick.
Die reicht dicke, klar!
Ich habe mal auf Raspberry 3B "downgegradet".
Mit dieser Config läuft es bis jetzt ruckelfrei:
Beim ersten Booten war die gestörte Wiedergabe noch vorhanden.
Ich habe dann auf Audio-HW-Info geklickt.
Vermutung: Eventuell wird dann die Karte erst richtig ins OS eingebunden.
Nach einem Reboot war alles "gut"!!
Morgen will ich mal mit einem Raspberry 3B+ die gleichen Tests durchführen.
- config.jpg (71 KiB) 9184 mal betrachtet
da ist jetzt aber die Samplerate des Systems auf 48.000 eingestellt. Ich weiß nicht, ob das nicht insgesamt weniger ruckelt, weil weniger gerechnet werden muss...
Hallo Hanno, es ruckel t mir der niedriegeren Samplingfrequenz über Haupt nicht mehr.da ist jetzt aber die Samplerate des Systems auf 48.000 eingestellt. Ich weiß nicht, ob das nicht insgesamt weniger ruckelt, weil weniger gerechnet werden muss...
Ich habe dann die SD-Karte in den Raspberry 3B+ gesteckt und einen Test gefahren.
Auch hier waren keine Aussetzer mehr.
Über HDMI (3B+) kam aber die Meldung, dass das System nicht ordentlich dismounted wurde ->pse run fschk
Ich werde morgen mal eine SD-Karte frisch bespielen und die Tests dann auf 3B+ noch einmal mit einer frischen Installation testen.
Soweit der Stand.
Heute Nachmittag hat sich nur mein Netzteil mit Micro-USB-Stecker des Netzteils verabschiedet. Zum Glück trat keine Überspannung auf und das USB-Kabel der Stromversorgung war noch verwendbar. Jetzt läuft es erst mal über ein Netzteil mit 2*10.000 UF und LT1083.
Hallo Leute,
ich würde gerne wissen wann die Testphase voraussichtlich abgeschlossen wird (nicht abgeschlossen ist, weil, das ist sie ja "nie")
und die Folgeversion von 3.50 bzw. 3.55Beta veröffentlicht wird?
Bin bestimmt nicht der Einzige den das interessiert.
und ungedultige Grüße
aroio 4.69
Raspberry 3B+ IQAudio
generierte und abgespeicherte Filter werden nicht angezeigt.
in AccourateCV werden 7 Filter angezeigt, in der Administrationsüberfläche des Aroio nur Echotest und Bypass.
Das generierte Filter kann nicht ausgewählt werden.
Mit Hifiberry Digi+ und Raspberry 3B+ funktionierte die Wiedergabe nur Squeeze.
Bei Auswahl des Convolvers trotz kleinster Sample- und Shareport-Frequenz und Quality low zu keinem funktionierenden System.
Fehlermeldung I2S sync error über HDMI.
